best antenna for bc125at
smiters
clarenville nl
hi guys just wondering if anyone could suggest a good antenna that can receive far distance, looking for one for outside as i have a small hill on both sides of my house and don't get good reception inside and I listen to frequencies between 123-175 VHF
Blackink
Central Vermont
Well, I don't really know what kind of antenna I have on my bc125at except it came from my BCT15x base unit.
It's a telescopic antenna and it works much better than the one that comes with the bc125at scanner.
I'm mostly listening to frequencies in the 153-159 range and the 450-460 range.
Others will post their thoughts and suggestions and I'm sure they can give you some names of good antenna's that will work.
They may want to know what frequencies you listen to mostly to zero in on an antenna that will work better for your needs.
smiters
clarenville nl
should have been more specific, looking for one for outside as i have a small hill on both sides of my house and don't get good reception inside and I listen to frequencies between 123-175 VHF
smiters
clarenville nl
thanks, I should have been more specific, looking for one for outside as i have a small hill on both sides of my house and don't get good reception inside and I listen to frequencies between 123-175 VHF
Blackink
Central Vermont
I use an ST2 antenna connected to my base but I've hooked it up to the bc125at also and I can pick up frequencies 60-80 miles or more away.
I like it but it is kinda big.
I too have mountains around me but I have it about 12' above my metal roof.
