5Rya
Planning on getting the BC125AT and primarily listen to VFH and UHF frequencies. What would be the best antenna to get? Thanks
Outside antenna? Inside? For your vehicle? A little more info is needed here. 73, n9zasPlanning on getting the BC125AT and primarily listen to VFH and UHF frequencies. What would be the best antenna to get? Thanks
There are Many to choose from, my choice is not the best but it works. I use a Mfj-1717 17" bnc whip. You can see it on Mfj.com :wink: 73, n9zasI will be using it inside my house walking around with it so it would be a portable handheld antenna.
Thanks Hans, lol. Yep, my mistake. . 73, n9zasI think you mean MFJ Enterprises Inc.?
Diamond RH77
For me the best I've found for VHF/UHF/800 is the Austin Condor.
prcguy
what about for a digital Phase 1 and 2 scanner? I live in the Virginia Beach. I can only pickup Virginia Beach . I need to find one that I can pickup Norfolk and Chesapeake. What is a good antenna for a Radio Shack Pro-106 handheld scanner?
The Diamond RH77CA does not work for me. I still cannot pickup Norfolk or Chesapeake on the 800 MHz.
Depending on your monitoring location you're more than likely not going to pull in the Chesapeake or Norfolk systems on 800 MHz with just a small duckie antenna of any kind. You may end up having to do something that's mounted higher than just on the scanner using an extension cable and possibly even doing the antenna mount itself outside or as high as possible next to or even directly on a window with the potential for non-blocked signal reception.
As a native of Portsmouth and a somewhat centralized location in that city I could, from that location, pick up most anything save for Suffolk and Hampton/Newport News traffic with a handheld but of course the last time I was actually "back home" was 2001-2002-ish so I'm sure things have changed. Even so, when I was at home and using a BC-246T the trusty RS800 and the Diamond RH77CA always seemed to get me everything I was hoping to monitor without issues and that included Norfolk PD/Fire and Chesapeake as well.
The Diamond RH77CA is a fantastic antenna in and of itself and works great even on the 800 MHz range but not if the system you want is a considerable distance away - for that you're going to want something tuned to the 800 MHz band specifically such as the RS800 (not quite so easy to locate nowadays) or the growing-more-popular-all-the-time Remtronix 800 MHz "clone" of the RS800 which many report to be as good if not slightly better than the good old RS800 that so many of us have come to depend on the past 20+ years or so. For 800 MHz systems the RH77CA isn't going to match the performance of the RS800/Remtronix clone, not even close, so if you really need to monitor those you're going to have to get an 800 MHz tuned antenna.
Your location in Va Beach will make a big difference because of sheer distances and obstructions along the way as the city tends to slope down in elevation towards the ocean edges in the southeast.
Newer scanners should have enough sensitivity to get something if you get the antenna up a bit, but unless you're living in some apartment building 15+ stories up you're going to have issues with reception from those two cities and just a handheld-mounted antenna.
True, effective for 700-800mhz. But not all that effective for Vhf/Uhf which is what the op mentioned he was interested in. My suggestion would be the MH-255 for vhf/uhf . 73, n9zasX2! The Remtronics antenna is VERY good and NO adapter is required for the Unidens if you get the SMA version!
GTO_04
