where can I purchase it?
Are you saying that the 7R stock ducky outperforms the RH77CA?I've been using a network analyzer at work to plot the return loss of various handheld antennas. I've only checked a few, and so far the best antenna for 2M/70cm has been the antenna that comes with the Yaesu VX-7R.
I have the VX7R and that stock antenna is by far one of the worst. I don't know where you get your readings at but most stock ducks are terrible except for the Kenwood duck that comes with the THG71A dual band radio. i special ordered one for my yeasu dual band!!!! kenwood antenna on yeasu radio!!! How ironic, but also works about as good as a RH77CA, on VHF-hi, believe it or not!!! except the RH77CA beats all at UHF!!!I've only checked a few, and so far the best antenna for 2M/70cm has been the antenna that comes with the Yaesu VX-7R.
No, I'm saying that the stock VX-7R has shown the deepest resonance at 2m and 70cm (of multiband performance) of the antennas I've tested. I have not tested an RH77CA.Are you saying that the 7R stock ducky outperforms the RH77CA?
I'd like a list of what youve tested.
Eric Burris kc0ldt
I believe the Pryme RD-98 is very similar to the ANLI (rebranded I believe). I have it and find it works very well. Got it at Frys.Best things I have found on dual-band handhelds are the hard-to-find ANLI ducks.
If you don't mind using a 15 inch antenna, the ANLI RD88H is the best. If you want a shorter antenna, the little brother to the 88H is the ANLI RD-9H. Both of them totally rock! They're available at AdvancedSpecialties.net, here: https://www.webtrix.net/shopcart/Ad...pringgreen>Handheld+Radio+Antennas</b></font>
They also carry the highly rated Maldol antennae. I've had dealings with that dealer and definitely recommend them, even if they are in New Jersey.
I had a RD98 long time ago but got tired of it whipping around, especially when i take a short jog or run for something. The RH77CA and equivalents I like better and more sturdy and like.I believe the Pryme RD-98 is very similar to the ANLI (rebranded I believe). I have it and find it works very well. Got it at Frys.
I also have the Pryme AL-800 which is the rebranded ANLI...Also purchased at Frys. Both work well.
On 800mhz, the RS800 works better though. Below that, I'd recommend either of the other two... But be aware the AL-800 is long and stiff. The RD98 is 17in and thin. Very whip like.
