Best Antenna for IC-R3 ??
AKJohnny
Scanner Addict
Kendall County, IL
Can anybody recommend a good 2.4Ghz mobile antenna that I can plug right onto the IC-R3 handheld? (Something with better gain than stock antenna)
Also, if you know of a good replacement all/wideband antenna that works better than the stock one, I could use a recommendation as well.
Thanks!!
iMONITOR
Silent Key
S.E. Michigan
Just about any high-gain antenna designed for 2.4GHz WiFi should work fine. Check for the type of connector required, try to avoid adapters.
AKJohnny
Scanner Addict
Kendall County, IL
That's part of the problem I'm having...I cannot find a "Rubber Duckie" style 2.4Ghz antenna or anything similar that plugs directly to the scanner without cable that comes with a BNC connector...which means I'd need an adapter.
ReceiverBeaver
Banned
May I ask just what is it out there that one can receive on a scanner at 2.4ghz? TNX
iMONITOR
Silent Key
S.E. Michigan
The Icom IC-R3 has a video screen. Most likely he plans on looking for 2.4GHz wireless video/security cameras, nanny cams, etc. But they are low power, and you need to be very close.
