best antenna?
italia2006
i have a pro 97 from radio shack and live in rocky hill. having a hard time to hear new britain and west hartford. if im in my car approaching berlin tpke i can hear them clearly, but from inside my house im hearing almost nothing. what antenna can i use outside /inside my house that doesnt stick out that much. on a side note oes anyone have 10 codes for newington and wethersfield. i have rocky hill and hartford if anyone needs them.
thanks for help in advance. im new to scanning and trying to get the best working equipment
cg
Connecticut
it is possible that you are getting some sort of overload. If this is the case, a "better" antenna may make it worse. If your scanner has an attenuator, try putting that on for WH & NB. If you live within 1/4 mile of a Nextel site, you may be out of luck no matter what you do.
chris
ansky
NJ
New Britain puts out a notoriously bad signal so I'm not surprised you are having a hard time hearing them. RS has an antenna specifically designed for the 800Mhz band, although I have never tried it so I'm not sure how well it works: http://tinyurl.com/2lqg3c
ledscan89
The 800Mhz antenna from Radioshack does boost the signal over the stock antenna. You may have better luck with that.
connecticut
Best antenna
The footprint (area of coverage) is limited for the City of New Britain. The radio signal barely gets into Newington. Although the City is working on a new Radio System it will be a few months before things improve and even then you may not pick it up in Rocky Hill.
ansky
NJ
Is the new system going to transmit from the same location? Rattlesnake Mountain in Farmington really blocks NB's signal from traveling west.
italia2006
thanks for the help everyone. i bought the radioshack 800 mhz antenna and it really does boost the signal tremendously.sometimes at night i can get bits and pieces of new britain.
it even works well for lower bands. i tried 3 antennas and this one works the best. the stock ntennas was ok. i tried " the conductor" by austin antenna but it doesnt work as well as the 800mhz from radio shack. another good thing about it is that it relatively small about 8 or 9 inches thanks again.
connecticut
best antenna
The main site (NBGH) will remain the same. Coverage should be improved depending on if they add one or two simulcasts. The study is being done now. Bids to follow.
