HH all,
I'm in an HOA but they don't care what your backyard looks like. I currently have an inverted V with the apex at about 25' with an angle of about 30 degrees. I can see from Grid Tracker that most of my contacts are to the NE. Since I'm in AZ, there isn't much left to the SW. My antenna, over the last 7-8 years is clearly biased toward the northeast and southwest.
My question is, do I increase the angle of the wire or look at an omnidirectional vertical. I do have 4 guy ropes up to keep it stable and it works well. I am renting and have a 35' telescoping fiberglass pole buried in the dirt so it's not going anywhere.
I'd like to maintain range as well as hit all directions, on a budget. What do you suggest? I would wrap a wire around the mast, not problem. I already have a 1:1 Unun at the apex.
Currently, at the apex, I have two wires in an inverted V configuration. I can operate 10, 20 and 80 meters without a tuner but 80m is around 3:1.
I've heard good things about decent, omnidirectional, multi-band antennas. What do you suggest? As long as the blue-hairs can't see it from the road, (I'm in a 2- story house), they don't care.
One last comment, I realize you can tune a lawn chair. That's not what I want. I want a good antenna that can do 10,20,40 and 80. If I have to drop 80, that's okay.
What are your thoughts?
