MStep
Looking for recommendatiions for an inexpensive laptop, preferably available on Amazon, to run Sentinel to program the SDS-200. Thanks.
What's your budget?
Sentinel does not require a lot of horsepower (speed & memory) to run. You would, of course, need internet access as well as be able to update the Dot.Net to the correct version.
I see this one at Best Buy:
There are a number of other options on Best Buy's site if you specify to search for 'under $200 laptops
Or this on Amazon:
Or this Lenovo @ $170.00 on Amazon
The first two have Windows 11, the Lenovo Windows 10. These are all "Windows S" versions, so you would need to remove the 'S' designation before it will allow you to install Sentinel. Instructions for that are easily found with a simple search.
One example: Switching out of S mode in Windows - Microsoft Support
Of course, if you look around, you may find an ever cheaper previously owned laptop at a pawn shop or estate sale.
I've been cranking along with an ASUS as well for years, for exactly the use you have! I just keep an eye on memory and delete stuff regularly. It helped to add a SD card and direct all scanner related software and apps to the D drive. Sentinel, ProScan and a few other bits live there and no longer am I almost out of memory!!!Looking for recommendatiions for an inexpensive laptop, preferably available on Amazon, to run Sentinel to program the SDS-200. Thanks.
I run Sentinel, Proscan, etc on a 1st gen Surface Pro Win 10, 64GB SSD, 4GB RAM while out and about, no problemsI did see a thread where someone was having a problem with installation on a system that had 4GB RAM, so you might want to go higher.
Why wouldn't they be? Got one in mind? Look up the specsAre windows based tablets strong enough to use Sentinal and ARC536 programming? Excluding the Surface Tablets.
Of course they are if they are able to run windows 8, 9, 10 or 11. If they were Windows Mobile... I would guess not but those would be quite old.Are windows based tablets strong enough to use Sentinal and ARC536 programming? Excluding the Surface Tablets.
They work fine for passing data. No idea on charging.Good morning.
My 11-year-old Toshiba is starting to show its age, and the only laptop I can find to replace it may be one of those newer, thin models.
The last time I looked, it seemed like most of the new, thinner laptops are using USB-C ports.
I understand there are adapters available for USB-C to USB connections, but does anyone know how well they work?
Thanks in advance.
-Johnnie (KC5IGH)
