I’m following this thread with great interest and hope to learn more about the versitality, especially how you propose to accomplish DB updtes without the use of a USB cable. Not sure I understand exactly what you are after so I offer this…
Since you stated you are using PROSCAN and Sentinel to do the DB updates, I agree with Buddrousa’s post. Your ONLY choice for DB updates is Sentinel until PROSCAN gets its act together. But Butel offers ARC which will also update the DB but only if you have subscribed to RR as a premium member (which you have). I believe PROSCAN would also require a RR premium membership. (Sentinel allows for the exact same DB update without the need to subscribe as a premium member of RR… but given the very reasonable subscription cost of RR premium membership and the fact I’ve been using Butel programming software since they began supporting scanner programming on previous scanners, I stayed with Butel. I believe RR should be recognized for its continued support of their programming software, especially after trunking came to be which made manual keyboard entry a time consuming chore (fraught with accidental entries). And since it predated PROSCAN, it was the only offering at the time. However, I applaud PROSCAN and FREESCAN for their ability to allow one program to service multiple scanners and have purchased my own copy of PROSCAN. But since I’m familiar with Butel, I’ve stuck with it. And regardless of which aftermarket software is used, Sentinel is still the only software that gives us the ability to grab Uniden’s firmware and software updates from within the Sentinel program. (I’m not all that familiar with PROSCAN, as to if they also allow for a link to Uniden for scanner FW updtes as Sentinel does but I don’t believe so.)
As for how I go about updating the DB, I first backup what I’ve been using, just in case… I can always revert back to it if I screw up any new profile I create. I access my programming software program on my computer (Butel ARC or PROSCAN) and download the latest DB from RR into it. After editing, creating FL’s, etc., I create a new profile. Once that is completed I download my new profile into the scanner using the patch cable.
My alternate method would be to download the latest DB using Sentinel, where the new DB is installed within the Sentinel program. But in both cases, a patch cable is required to then push the new profile I’ve created into the scanner’s memory banks.
My method(s) requires that patch cable between the computer and scanner… wondering how this could be accomplished without that patch cable? Or am I missing the meaning of the OP’s question?
