What's the best hi gain nmo moblie antenna?
I'm looking at Comet 2x4 but are there any other high gain gmrs antennas
Skip the hammy/hobby grade stuff if you want something decent. There's nothing magical about those antennas, and most of them are butt ugly.
Stick to what the professionals use. Usually cost is the same or less than the hobby grade antennas, and it'll easily outlast your vehicle. There's a reason why fire trucks, ambulances and police cars are not running these ham grade antennas.
I've got Larsen antennas that are 30+ years old now, still working as well as the day I bought them.
I've been using them at work for about 20 years now, no issues.
I recently started spec'ing EM Wave antennas and am thoroughly impressed with their stuff.
As for high gain, remember that everything is a trade off.
Higher gain is achieved by changing the radiation pattern of the antenna. A higher gain antenna will focus energy at the horizon, which can be good in some applications. If your vehicle gets into the mountains, dense cities, or places where you are at extreme angles to the other radios, high gain can result in energy being focused above or below who you are trying to talk to. Higher gain antennas are longer, which can create clearance issues if you have a tall vehicle or wander into low tree branches or parking garages. Higher gain antennas also give up useable bandwidth. Not an issue when you only need GMRS, but if you need additional spectrum, it can work against you
Low gain antennas can work better in some applications. Lower profile, too. But will give you a bit less range if you are out on the plains. They will have much wider usable bandwidth, which can be good if you want to listen to other frequencies in the UHF band, or if you get your ham license and want to program some ham/70cm frequencies into your radio. Usually less expensive than the higher gain antennas, also.
And remember, there's no reason to search on "GMRS antenna", unless you want to pay extra. All you need is an antenna that will cover the 460MHz band, and you'll be good. Most amateur radio antennas are not designed to work in that portion of the UHF band.
A good medium gain antenna can be a good all around solution.
EM Wave:
UHF 3dB gain roof mount antenna w/ spring 420-470 MHz (tunable range)
theantennafarm.com
UHF 5dB gain roof mount antenna w/ spring 420-470 MHz (tunable range)
theantennafarm.com
UHF 3dB gain roof mount antenna, e/m-Flex® Poly spring 420-470 MHz (tunable range)
theantennafarm.com
Larsen:
450-470 MHz Base loaded 5/8 wave 3dB antenna with integrated spring. Maximum Power 200(Watts), Whip Length 19"
theantennafarm.com
450-470 MHz Wideband Antenna. Gain (dB) 3.5, Maximum Power 200(Watts), Whip Length 35 1/2"
theantennafarm.com
