Best Lowband Mobile Antenna?
markclark
Nevada Range
That's right, go commercial all the way with low band. Low band has unique characteristics, so it follows, you need good commercial equipment to get it right.
I have two Motorola Syntor X9000 and Two Kenwood 690 commercial radios for CHP and base loaded whips from Laird, Motorola, Antenna Specialists and an $18 E-Bay knock off. Low band works well with a scanner on very local systems but when you monitor statewide and large county systems you need good equipment for low signal strength areas--and most important- you need the noise blanker circuitry commercial radios have. Good luck!
