Best method to attach cable to car
K6DDL
Tacoma, WA
what tape have you found best to attach antenna cable to the surface of a car? I have the cable running across the roof and through the weatherstripping, but I can't find a good method to hold the cable alongside the weatherstripping in the door frame. Electrical tape doesn't stick.
jonwienke
More Info Coming Soon!
VA
There isn't any tape that is going to work well for any length of time. Anything long-term would require drilling holes to mount the wire clips/retainers. And if you're going to drill holes, then you should just do a permanent mount and run the coax inside between the headliner and sheet metal. Magnetic mounts are for temporary, not long-term applications. A properly-done permanent install will work better and have lower SWR.
mule1075
Washington Pennsylvania
Wire ties wrapped around the weatherstripping will work in the short term.
Sent from my Z750C using Tapatalk
Get yourself some "Gaffers Tape". It's like Duct Tape on steroids. I've used it in some installs to keep coaxial cable up out of the way under/above headliners.
Make sure you clean the area where you are going to attach the tape, any grease/dust will reduce the effectiveness of the adhesive.
902
Downsouthsomewhere
An installer at a former employer used plastic tie wrap blocks RTV'd into place, then tie wraps run through those. It worked better than I expected it to. I don't know how well that would work in a door, though. They did it up the outside of the windshield.
dmg1969
Newport, PA
I used the tie wrap blocks from Radio Shack on my last vehicle when I had first used a magnetic mount. I had the coax coming in through a door jam and it worked very well to hold it exactly where I wanted it. Granted, that was hidden behind the doors and not exposed directly to the weather. I'm not sure how they would hold up then.
Sent from my iPad using Tapatalk
