Best NMO for 2011 Ford Explorer.
KC9AAQ
SE INDY AREA, Indiana
Needing to install NMO mounts on a 2011 Ford Explorer, what type of nmo mounts 3/4 or 3/8 would you suggest? Pro's and con's. Will be using low profile antennas.
Thanks: Greg
3/4" standard NMO.
If you are going to drill a hole, drill a hole. The 3/8" doesn't gain you anything over a standard 3/4". Properly installed per manufacturer directions, it'll easily outlast the vehicle.
Pro's to the 3/4" is you can easily install them from outside.
Con's to the 3/8" most of them require installing them from inside, which means dropping the headliner.
Either one will work fine.
