Best P25 wait time Was: Help
AK9R
Staff member
Super Moderator
Central Indiana
Which scanner?
chrisZent90
WV
Bcd325p2
and what is better is scan or id search
and the best p25 wait time
on the wait time is it the lower so faster is it to resave the p25 frequencys
n1chu
Farmington, Connecticut
I would leave the wait time to the default setting. I would use ID Scan unless you don’t know the ID and wish to learn it. If it’s scan speed you would like to improve, timing it both ways to compare, the difference between zero wait time and 200 isn’t a noticeable difference really, is it?
chrisZent90
WV
I use the dce numbers on radiofrequency
Is that the same as the ID.
My default is 400
chrisZent90
WV
My default is 400
JoeBearcat
Uniden Representative
Set it too short, and you will hear data at the beginning of digital signals. Set it too long, and you will miss the beginning of analog signals.
400 is a good compromise.
chrisZent90
WV
I have the correct frequency for metro 911 but I don't receive nothing. And I have the Primary and secondary frequencies
