Best place for mobile scanner antenna
I drive a 2012 Volkswagen Jetta; what the best location for best reception? The trunk lid or the roof? Thank you. Should it be in the middle or to one certain side? or?
scannerboy01
Alberta, Canada
Wirelessly posted (Mozilla/5.0 (iPod; U; CPU iPhone OS 3_1_2 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7D11 Safari/528.16)
My suggestion would be on the roof as long as it isn't too tall and wouldn't hit things above. The kind of antenna would depend on what frequencies you are monitoring. Placing the antenna on the roof would be the easiest because you could run the wire through the door or window. If you placed the antenna on the trunk, you would have to run the wires under the body of your vehicle.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9780; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
Center of the roof. This gives you the best groundpane, and gets the antenna up and clear of the roof of the car
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Is the roof of the car metal? If so, that is the best place, for maximum signal.
Placing the antenna on the trunk often leads to fading of signals that are coming from the front of the car.
