any advice as to the best receiver specifically for airband? it dosent need to do any other band, it can be a tranceiver if nessicary... im looking for sensitivity, so I'm guessing most scanners are out... looking for something <$1000
well the radio will not be scanning so thats not a concern... im mostly concerned about sensitivity/selectivity... im trying to pick up some far away airports to stream them online....
setup is going to be like this
antenna > coax > air band pass filter can > preamplifier > receiver multicoupler > radios > PC > internet
Hi flecom, what distances are you looking at?
That's exactly my setup, and what I use them for.
I believe that one of the transceivers people are talking about would be better than a scanner, but I only have a couple of Uniden BCT-15s, so can't compare them.
I can tell you though, that I can hear aircraft very strong & clear out to 200 NM from me. I know this, because all aircraft arriving, departing and even transiting within 180 NM are required to check in with New York Oceanic here in Bermuda (one of my Internet feeds), and the aircraft for example are advised "radar identified 20 miles east of BALOO", which itself is 180 NM from me. Actually, it's 180 miles from the VOR, so tack on another 6 miles or so. But, I digress.
Again, the reception often (depending on aircraft) is mostly pretty strong & crystal-clear. Even the weak ones are still readable.
My antennas are what makes the difference, though. I've tried a few, inluding an LP (log periodic), but the best one I've come across is my current 12' vertical, which is a professional antenna from a company called Procom in Denmark. The model is their CXL 3-3C. It wasn't cheap (cost me almost $1000 for the antenna, plus shipping from the UK and duty when it arrived here). But reception-wise I feel it's worth it.
Again, not having a dedicated airband-only receiver/scanner to compare my setup against, I can't comment much more. When you say "far away airports" stations, how far from you are those stations? Your mileage, as they say, will vary, as except for a few hills around here (on land), the signals that I'm receiving are traveling over at least 175 NM of ocean, with no obstructions.
Here's my equipment, including the filters & preamps, etc.
BikiniWings/FusionWings/GenealogyWings - My Toys: Radio Equipment
The lower (LP) antenna in the top pic is disconnected, and not in use. Don't know if it's interefering with the top one's reception.
Sorry I can't be of more help, with any definitive answers for you. All that I can do is offer my results that I'm having with my equipment for also picking up distant communications.
Have a great weekend. Happy 4th.
P.S. The reason why I went with a couple of BCT15 scanners (and their expense), was that I wanted to make use of their audio Line-Out capability, fed into a couple of PC's audio Line-In inputs. I do notice a distinct difference between using the simpler (plug-in-and-forget) Line-Out outputs (rather than Speaker-Out outputs). Likewise, I only use Line-In inputs, rather than Mic-In, as I notice a difference there too.
The D700 is actually a pretty decent aircraft receiver. I think you'd be a lot further ahead spending that $1000 on a tower and antenna. You problem isn't receiver sensitivity, it's physics. Aircraft transmissions are basically line-of-sight, and if your antenna is so low that you're below that line, you're SOL. Get that aluminum up in the air!
i am on top of a 5 story building and the antenna itself is 23' tall... think it would be pretty hard for us to put a tower on the building...
Hate to say it, but in that case you may just be screwed. There really isn't that much difference in sensitivity between a dedicated airband transceiver and a good scanner.
wow really? your telling me a scanner with no front end letting in all sorts of crap from DC to light is going to be just as sensitive as a commercial airband receiver with a real front end?
i guess everything ive ever known about RF is incorrect :lol::roll:
I have had very good luck with the Uniden BC780/785/796/BC15 and BC996 receivers over the years on airband, they seem to have a great mix of sensitivity and selectivity on both UHF and VHF air. My R8500 and R7000's work about as well, sometimes a little better on VHF.
I don't really see too many scanners comparing that closely to the Icom 8500, especially the ones you have listed. Of them the 780 has closest shot. The Icom 8500 easily out performs those radios in every aspect of receiver performance.
In regard to the best radio for airband reception there are alot of factors that can come into play.
I live somewhat in the country and this allows me to use higher gain preamps with radios that would not handle a preamp at all in a high RF area. In a clean RF area or with bandpass filtering the Pro-2045 is the best base model scanner available for UHF 225-400Mhz reception. I have owned I think every scanner ever made, thats no joke, and the 2045 is the only scanner that use for 225-400Mhz reception. Depending on your RF surrounds you may not be able to repeat my results. My exact setup moved to your QTH my become overloaded or de-sensed by nearby transmitters and become almost unusable. To avoid all variables in RF population of your QTH I would say by using a bandpass filter with a Pro-2045 and a 10-20db gain preamp for the 225-400Mhz band combined with a outdoor antenna as high as practical with low loss feedline you could not go wrong and it would cost lots and lots of money to outperform a setup like this.
Jody
