Of all the NiMH batteries out there, those two are the worst.Some like the Duracell 2650's some like the Engergizer 2500 nimh
This is a vast topic, and there have been 1000s of posts here on it. Do a search for "NiMH" and you'll quickly see what I mean. This thread has many answers you seek:Why do you feel the Energizers are the worst? ... What battery do you feel is better?
I run a mixture of the Duracell 2650's and Energizer 2450's and use a Maha charger. I have never found that the Maha wont properly charge these batteries. The only time I have had a problem is when they show a "high" reading when refreshing. When that occurrs, it's trash can time for the battery.
GM, as an avid reader of your posts, I'm kinda surprised to hear you say you've had trouble with these batteries and the Maha brand. They seem to have a good reputation and my unit has worked almost 24/7 for the last 18 months without a hiccup. (I believe my model is the C9000)
I certainly value your opinion, GM. You are certainly in the know and a source of great help to many here....
What are the best rechargeable batteries to use with scanners psr 500,pro96
Thank you. I entered into this topic many months ago fairly blindly. I have a lot of scanners (and other devices that use AA batteries), had many different brands of batteries, and had been using those throw-away chargers (that didn't charge batteries separately). After reading many posts here from many people, I purchased the Maha C9000. My initial reaction regarding the charger was that it is junk. I was so upset with its performance that I posted reviews of it in several places (copied one of them here on RR) and wrote to the manufacturer.GM, as an avid reader of your posts, I'm kinda surprised to hear you say you've had trouble with these batteries and the Maha brand. They seem to have a good reputation and my unit has worked almost 24/7 for the last 18 months without a hiccup. (I believe my model is the C9000)
To my surprise the manufacturer replied back and I worked with one of their engineers for several weeks. First he sent me a replacement charger. The two units (both C9000s) worked identically. I numbered each of my batteries and kept an extensive log of how they were treated by the C9000 and my scanners. Ultimately I sent samples of each of my batteries off to Maha. Bottom line, they blamed the batteries for how their charger functions (or more like how it does not function).
My bottom line here is that the C9000 can not, or will not, charge batteries which have a high impedance. It is not just in refresh or analyze modes, it is in all modes. Certainly I was able to continue to use the Energizer & DuraCell batteries, and charge them with dumb chargers or the scanners. But in doing the calculations, they were no longer giving me even 2000 ma hours of life, let alone 2500 or 2650.
In order to satisfy me, Maha sent me 5 sets of their PowerEx batteries. Of course so far the C9000 has not failed to charge them. Perhaps it won't. Time will tell. In the mean time I've been able to analyze other brands of batteries I own, and I am very happy with the blue Rechargeable (not green) and Chicago Electric brands of all things. At this point a few months later, I have discarded the DuraCells & Energizers as they no longer can power anything for very long and/or don't hold a charge.
There are a lot of threads here on this issue, and one which I've posted with the above, but not recently. Several other RR members replied and many came to the conclusion that Energizers simply have a higher impedance right out of the factory. This makes the C9000 & Energizers incompatible, so you must be charging them via other means.
When it comes to batteries, it proves you get what you pay for.
No. Energizers are bad for several reasons. First of all, I did not get nearly the life out of them as I have other brands (charging some sets in scanners and some sets in cheap chargers). Also, I do not believe I got the run time out of them I should have. The reason I say this is that I have other batteries of at least 2300 mah that run a lot longer than 2500 Energizers.So you're saying that the Energizers are the worst only because they don't work with your charger? I have been using them with my charger (RS and Digital brand) for a couple years now in my radios and GPS units and have had zero issues with them.
The issue is the internal impedance of the battery. Basically it is the underlying factor which causes them to be very hot while charging. Do some searching of threads here at RR and you'll find lots of others discussing how hot batteries get in their radios (when charging), they too have issues with Energizers (or DuraCells) and that many people feel they are throwing away good money if they do not purchase specific NiMH AAs that have proven themselves. PowerEx and Sanyo Eneloops are two that people like.
I am in the midst of running many sets of batteries through their paces to know fully how I feel. It takes time to know how well they behave over time. So far the 3 brands that failed totally for me are the DuraCells (especially 2650s), Energizer 2500s and green Rechargeable brand. Additionally you might get one set of the same brand of battery that works better or worse than a nominal set of the same brand. I've seen that too.
Yes and no. I did get some bad batteries. This is especially a problem when you buy "store brands", as they just put their name on products they had the lowest bidder supply. One specific brand I bought was great the first time, and dysfunctional subsequent times. In looking at the fine print, I found they were made in different countries.I wonder if maybe you got a bad set of batteries. I have been on the same few sets for a couple years now (at least) and still get excellent run time out of them. Sure they get hot while charging but not any worse then any other battery I have charged.
And I've had off brands that worked better than the name brands - especially Energizer & DuraCell. In another thread, the issue of battery capacity was discussed. In other words, higher capacity batteries are more likey to have problems than lower capacity models.At the same time I have had some off brands that failed miserably. At first they seemed like a hit but those suckers sure didn't last very long. I'm not knocking your tests at all, I'm just giving you my experience with the energizers.
