You will be limited in quality/performance by going with UHF on one side. Good commercial SMA to N adapters used in the microwave industry can be rated to 10-12GHz with very low loss with some rated to 18GHZ. These will usually cost in the $35 to $50 range and will be machined from solid stainless steel. Once you go to a UHF connector your usually limited to about 500MHz and the connector will be cheaply plated with chrome or nickel or a token layer of gold and can cost $2.50 to whatever but overall very cheap. You get what you pay for.
So asking what is the best UHF to SMA adapter is a bit like asking what is the best cow pie? Herford? Red Angus? Holstein???
