How does one go about viewing the status of assigned Department quick keys while using the scanner in order to then activate or de-activate a department?
The prior gen 996XT and 396XT radios displayed two lines, one for the Systems status and one for the Group status of assigned quick keys. The Group line (now called Departments) appears to be gone on the new scanners, which instead has a line for Favorite Lists.
Is there a way in the new X36HP scanners to display a line for the Department quick keys? If not, then how can you determine, while using the scanner, if a Department is activated or not?
(I am using a BCD536HP but I assume the processes the same for a BCD436HP.)
Thanks.
Thanks.
