I have been given 2 Feeds from Broadcastify with all different URLs and applicable settings, which are different for each feed. However, when I open a second Radio Feed on the same PC it is disconnecting the first instance of Radio Feed when I select “Connect” on the 2nd instance. I also get to the port mounting Error 3 code.
Each copy of RadioFeed has to have its own folder to separate each instance. You may also have to rename the .exe for each instance. ie: RadioFeed 1, RadioFeed 2, ect.
