yes, it goes back to (28) and I'm not in the program at all. I close it, make the change, get out of regedit, open the program, no P25.
Go back to regedit, value is back to (28)
EricCottrell said:The other possiblity is that the program reads the radio and sets the values as well. I do not have a radio. Scott should try it on the computer with the radio connected.
73 Eric
vince48 said:yes, it goes back to (28) and I'm not in the program at all. I close it, make the change, get out of regedit, open the program, no P25.
EricCottrell said:I was able to take a look at the R2500 on a break. The power and ground contacts look similar. There is a transistor missing used to switch power on and off to the P25 option socket so it is not just the connector that is missing. I will know more when I get a chance to scope it out.
However I got an idea. The DV and P25 option boards have a option power mode that can be auto (which is the default) or on.
EricCottrell said:Hello,
However I got an idea. The DV and P25 option boards have a option power mode that can be auto (which is the default) or on. Auto means to turn the board on when the mode is selected and on means on all the time. I suggest that the DV setting be changed to ON. See Page 119 for Software and Page 59 for R2500 control head. After it is set power the radio off and exit the control program. Power up the radio and see if the P25 functions get enabled.
73 Eric
