Bf-f9 v2+ dual watch tx-ab question
wcrosman
Longmont, CO
So I set me f9 to dual watch using menu 7. Works great. But when I use menu 34 tx mode, it seems it doesn't do anything a/b/off all seem tto transmit on the channel last selected. Anyone else seen this issue? Or, am I just a dumb ***?
Thanks.
SpugEddy
Camden County South Jersey
Menu 34 works in conjunction with Menu 7.
If you want to monitor 2 channels at once then set Menu 7 to "ON"
Now because of how the Baofeng is setup.
Whenever A or B goes active, the Baofeng will default to
TRANSMIT on that Channel.
So, Menu 34 can be set to "OFF" "A" or "B"
I'm not 100% but you might want to set Menu 34 to your
choice of A or B. Then set Menu 7 to "OFF"
St. George, UT
Spugeddy is really close with his response. With menu 7 TDR on, the radio will "listen" on both A & B frequencies. If Menu 34 TX is set to "both", when you push the PTT button, the radio will transmit on the last channel that had a receive signal, regardless of the which one is actively selected. example: TDR is on, you are selected on channel B (the lower one), and the radio receives on Channel A, the next time you push the PTT button, the radio will transmit on Channel A.
If you set the Menu 34 TX to A, the radio will only transmit on A, B will only transmit on B. If you set this menu to off, the radio will transmit on whatever channel is selected, as indicated by the arrow
