Birmingham/Jefferson...whuh?
arturobandini
I knew the BPD went to encryption but where is everything else? Perhaps I'm doing something wrong.
I had fire, sheriff, UAB, airport operations, CAPs, Weill wrecker programmed and they are all gone. I hadn't been scanning in about a year and today and I checked and nothing. I have a Pro-651.
dave911
Hoover
Check the database. If it’s been a year, you need to update your frequencies. Hope that helps!
arturobandini
All of those places changed their frequencies in the last year? That seems like one hell of a coincidence.
  • Haha
Reactions: RRR
dave911
Hoover
The system did. Are you using the 700mhz frequencies? Look at the AFRN database.
arturobandini
I don't use software and I've been advised that my scanner, the Pro-651, is not capable of receiving AFRN.
tvengr
Well Known Member
Baltimore County, MD
AFRN is P25 Phase 2 capable but Jefferson Co Sheriff and Fire and Birmingham Fire are all operating as P25 Phase 1 which your scanner can receive. Birmingham PD is fully encrypted so you will not be able to receive that. You may have simulcast distortion problems with your scanner depending on your location.
arturobandini
I thought everyone had moved over. I had things like Weil Wrecker, UAB police, JCSO, CAPs, and the airport programmed and they are all gone. I had only been away from scanning for, I don't know...8 months or so? All of them, every single one of them, decided to change frequencies in that amount of time?
I was told everything moved to AFRN. Perhaps I misunderstood.
arturobandini
Right. And the Pro-651 cannot operate on the AFRN system because it is not Phase 2 capable. It's now a doorstop. :) It gets nothing anymore.
tvengr
Well Known Member
You can receive any phase 1 talkgroup where the Mode is D. If the Mode is T, that is a TDMA (Phase 2) talkgroup which your scanner cannot receive.
arturobandini
This was very helpful, thank you. I'm starting to wonder if something happened to my radio in the last 8 months. I think it was still programmed, but I heard nothing.
