danpforsich
- Joined
- Mar 2, 2021
- Messages
- 4
I apologize in advance for the idiot-level question this will probably end up being. I work at a rural fire department and had a box of BK radios dropped in my lap by my chief and know very little beyond daily usage. Trying to clone a GPH5102XCMD to another using a LAA0700 cloning cable. Successfully put the radio in programming mode, attached and turned on clone radio, pressed * key on master radio, then FCN key on master radio. Master radio lists "cloning" for only a second before saying "failure". Manual lists possible causes as "incorrect radio types", "improper connection", "failure to power up radio", and "clone set in programming mode". I think I have ruled each of these things out. Any help would be appreciated. Thanks!
