BKR 5000 & 9000 Command Zone Programming
rsmith7799
Arroyo Grande, CA
I've noticed an issue when programming for especially a MASTER Radio to clone others and in the computer program of RES.
When setting up a MASTER radio and a MASTER program, please make sure that you ALLOW for Frequencies and Channels to be front panel programmed into your Command and Incident Zones.
In RES, for these Zones, go to Zones Settings on the right hand side, open up the tab and make sure that you check/uncheck the following:
CHECK Allow Cxcss Selection On All Channels
UNCHECK Disable Keypad Programming
CHECK Command Zone
CHECK Zone Scan
Incoming Clone, ACCEPT
You must do this for ALL of the Command and Incident Zones. This will NOT affect the other Zones.
IF this is not followed, you can not ADD any channels or frequencies into your COMMAND or INCIDENT ZONES.
rsmith7799
Arroyo Grande, CA
CHECK Command Zone
CHECK Zone Scan
And after reading a few comments on other pages that I posted this, this does mainly pertain to "A CALIFORNIA THING"
