BKR 9000 Keypad mute
Smokie493
Allen, texas
Just received my BKR 9000 radio and I am very impressed with it. All programmed up and works flawlessly. Is there a way to mute the keypad tones? No option in the software to add a mute button. Still scratchin' my head....
Thank you for your help...
rsmith7799
Arroyo Grande, CA
Good morning Smokie, so under Config MENUs (top of the RES, Radio Menu Configuration, there is a KeyPad Mute that you must add to the Menu Items. See how that works. I've seen it, just never used it.
PacScan
Los Angeles
Thanks for asking this, it reminded me to add it to my configuration. (Still waiting on the radio to arrive however, how long did it take for you?)
Smokie493
Allen, texas
Thank you for the answers. I looked and it's not in the menu items, Conventional or trucked. Listed as something else? I'm running software ver Version 5.8.28.
It took approx 180 days for me to receive the radio..
rsmith7799
Arroyo Grande, CA
As a Dealer, I got mine relatively fast. But mine are for demoing to Departments. I have a dat. file I can send you. DM me and give me your email.
Give me a call 805-714-8875 but first update your software to 5.8.38
Smokie493
Allen, texas
Problem solved with the help of Rick -rsmith7799!!!!
Updated software and the selection appeared.
THANK YOU RICK!!!!!
rsmith7799
Arroyo Grande, CA
So to finish up on a question Smokie493 had, in Software 5.8.28 this option is not there. But in 5.8.38 it is in there.
PacScan
Los Angeles
Did some testing with this, running into an issue where if the keypad tones are muted, then you cannot change zones.
You can click "ZONE", scroll to what you want, click "ENT", but it won't change. The moment you click "MUTE" again, it will take effect and you will jump to the selected zone.
redtrailb
This bug was corrected in the 5.10.37 firmware, which doesn’t look like it was publicly released (I received direct from support after highlighting same issue). There is finally a new public release on their site (5.10.43) that you should try if you haven’t already, should fix the issue.
PacScan
Los Angeles
I just tested, and that resolves it! Thank you!
