Blank LCD screen
oralsurg
Abilene, Texas
Just got my TRX-2
I did all the firmware updates an loaded radio reference
now when I turn it on I get a blank screen with the backlight on. I can push WX an get the weathe.
I did the one minute put to turn on too. Tried changing contrast too.
Any suggestions?
tvengr
Well Known Member
Baltimore County, MD
The SD card can cause display problems. In TRX-2 EZ Scan, go to the Scanner/SD Card tab and Prepare Scanner Memory/SD Card for use.
gh6406
Dalton,Ga
With power off and disconnected, remove and replace front panel a few times, then with front panel connected, repower and see if that works. If not, with power off, remove sd card and replace several times say 3 to 5 times, then reinstall and repower.
