Block reception from a specific radio ID
salarazad
Hi everyone,
At on location we have two base-stations (DM4601e) close by, and they are both on the same channel; so when talking on one of them I can hear myself on the other one which is annoying.
Is there a way to block the communications between these two base radios without affecting the communications to the other radios?
Is there a way to block or blacklist a radio ID? so we don't receive from that radio.
Many thanks!
Floridarailfanning
East Tennessee
Not that I know of.
But, it should be possible to mute one when the other is transmitting by connecting to the correct pins on the rear connectors. Hopefully, someone who has set this up before can chime in.
salarazad
In DMR mode, if you program both bases with the same ID, they should not hear each other.
We are using DMR and both stations are configured with the same Radio ID as you can see in the attached photo, but they still hear each other.
Please by ID did you mean the Radio ID in General Settings or another ID?
Thanks!
N1GTL
CT
You can use an external speaker and build a simple "circuit" off the rear connectors that will mute the external speaker when the other radio keys up.
salarazad
Not that I know of.
This method sounds very interesting, but I couldn't find any thread or resource online on how to connect two base-stations together with the rear connectors pins.
Can you please refer me to a site or a link?
Many Thanks
salarazad
This solution is a little complicated for me, but I would still like to give it a try.
Can you please share a document or a link explaining it if you have.
Many Thanks
