bloomington indiana question
Tomcu96
elletsville indiana
So I'm trying to see if you guys have a radio system like the area 10 because for now on I don't see that they use the radios and for the database admin, Bloomington transit hax to change there radio frequncies
Tomcu96
elletsville indiana
area 10 angry on aging doesn't use radios anymore the buses mostly use like there tablets. I don't think yellows taxi ether
west-pac
The taxis too!! 😵 The audacity! What in the frisbee is going on 'round here?
Tomcu96
elletsville indiana
I don't know because I don't I tried that radio frequencies that doesn't work plus I don't see them the only ones I see are the Bloomington transit busses
463.2375WPNZ731RM123.0 PLYellow TaxiYellow TaxiFMNTransportation
INDY72
Indianapolis, IN
Up here in Indy, most taxi do not use radio at all anymore. They use a app or a ip based mdt type system for all bids, trips, etc, and cell phones.
Whiskey3JMC
Quiet numbskulls I'm broadcasting!
Simulcastylvania, TE
The license was renewed last month so they're keeping it around for some reason. If you are using a scanner that discriminates scanning based on service types (Uniden x36HP, HP-x or SDSx00) be sure "Transportation" service type is turned on otherwise it will be omitted from scan. If no joy, remove the PL tone from your programming. Do you hear digital emissions? This would be an indicator if they moved to DMR or some other digital mode.
I want someone to change it on the database.
Someone has to have updated info and then submit the update for it to be reflected in the database...
