Blue Angels frequencies
recon225
Central New Jersey
The Blue Angels are coming to McGuire AFB in June and I am wondering if they use the same frequencies for the entire season?
Their website states the frequencies are not published due to safety concerns that someone can interrupt their show communications. It would be nice to get the frequencies other people have noted in earlier shows in the 2005 season in time for the June show.
cassidy1190
Belmar, NJ
121.9000----BLUE ANGELS - GROUND SUPPORT
123.4000----BLUE ANGELS - COMMON AIRSHOW
134.1000----BLUE ANGELS - GCA COMMON
142.0000----BLUE ANGELS - MAINTENANCE ALFA
142.2625----BLUE ANGELS - GROUND SUPPORT
142.6250----BLUE ANGELS - MAINTENANCE
143.0000----BLUE ANGELS - MAINTENANCE BRAVO
141.5600----BLUE ANGELS - MAINTENANCE CHARLIE
142.0250----BLUE ANGELS - MAINTENANCE DELTA
143.6000----BLUE ANGELS - MAINTENANCE CHANNEL 10
241.4000----BLUE ANGELS - AIR/AIRCHANNEL
243.0000----BLUE ANGELS - EMERGENCY
250.8000----BLUE ANGELS - AIR/AIRCHANNEL
251.6000----BLUE ANGELS - DEMONSTRATION
263.3500----BLUE ANGELS - FLIGHT LINE COMMON
263.5000----BLUE ANGELS - AIR/AIRCHANNEL
275.3500----BLUE ANGELS - COMM 1 LEAD & FORMATION
302.1000----BLUE ANGELS - COMM 2 TALKBACK
302.1500----BLUE ANGELS - COMM 3 SOLOS
307.7000----BLUE ANGELS - COMM 2 FORMATION TALKBACK
345.9000----BLUE ANGELS - AIR/AIRCHANNEL
360.4000----BLUE ANGELS - COMM - SOLOS
362.6000----BLUE ANGELS - AIR SHOW CONTROL
384.4000----BLUE ANGELS - AIR/AIRCHANNEL
391.9000----BLUE ANGELS - AIR/AIRCHANNEL
395.9000----BLUE ANGELS - AIR/AIRCHANNEL
408.4000----BLUE ANGELS - GROUND SUPPORT
418.0500----BLUE ANGELS - GROUND SUPPORT
mattcawby
They used these in Seattle August 2004:
163.000 237.800 265.000 284.250 305.500
edN
Birmingham
As of November 13, 2004
(*)CONFIRMED
(**)CONFIRMED 2004
BLUE ANGELS
141.850 Blue Angels - Air2Air
142.000 Blue Angels - Maintenance Alpha (NBFM) - Comm Cart
142.025 Blue Angels - Maintenance Delta (Repeated on 142.625)
142.625 Blue Angels - Maintenance Delta (Repeats 142.025)
143.000 Blue Angels - Maintenance Bravo (NBFM) - Tower Observer
143.600 Blue Angels - Maintenance (NBFM)
163.000 Blue Angels - Ground Ops
164.900 Blue Anges - Maintenance (NBFM)
165.225 Blue Angels - Comm Cart
168.900 * Blue Angels - Maintenance (NBFM)
169.400 Blue Angels - Maintenance (NBFM)
170.900 ** Blue Angels - Maintenance (NBFM)
236.450 Blue Angels - Fat Albert
227.175 Blue Angels - Interplane
237.800** Blue Angels - Solos 5/6
238.150 ** Blue Angels - Air-to-Air/Solos Ch8
238.250 * Blue Angels -
241.400 ** Blue Angels - Air-to-Air
249.625 Blue Angels - Aircraft 5/6, SOLO
251.400 ** Blue Angels - Air-to-Air*
251.600 ** Blue Angels - Aircraft 5/6, SOLO
254.500 Blue Angels -
256.250 Blue Angels - Unid
263.350 ** Blue Angels - (Aircraft Maintenance)(CH-10*)
263.500 * Blue Angels - Air-to-Air (Fat Albert"
263.550 ** Blue Angels
264.350 ** Blue Angels - Diamond Ch9
264.550 ** Blue Angels - Diamond/Solo
265.000 ** Blue Angels - Com-1
270.800 ** Blue Angels - Chat
273.300 Blue Angels - Fat Albert Ch10
275.350 ** Blue Angels - Aircraft 1-4 DIAMOND (CH16)
284.250 Blue Angels - Diamond
286.000 Blue Angels - Unid
299.650 Blue Angels - Aircraft 1-4 DIAMOND
302.150 ** Blue Angels - All 6 Aircraft
305.500 ** Blue Angels - Fat Albert
307.700 ** Blue Angels - All 6 Aircraft (Alternate)
321.100 Blue Angels - Operations
322.600 Blue Angels - Unid
345.900 ** Blue Angels - Air-to-Air Solos (CH-18*)
381.000 Blue Angels
384.400 Blue Angels - Air-to-Air
394.400 * Blue Angels - Air-to-Air*
As stated by mattcawby, they switched several freqs last year. After the first few shows, we'll know if they're using the same freqs this year.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
cassidy1190 said:
Go to this website. This guy did an excelent job getting all the milair frequencies for the McGuire area.
http://hometown.aol.com/jerseymilair/jerseymilair.html
And don't forget to check MT's article on monitoring the military air shows. It should have a good section on Blue Angels; in fact, I believe that the article is scheduled for updating in this month's issue.
73s Mike
timmer
Springfield, Il
I went to one of last years' shows. The following were in use:
284.25 diamond formation
265.0 solos
238.15
299.65
381.0
170.9 ground crew
375.35 all six aircraft
249.625
236.45
254.5
273.3
263.35
Hope this helps.
timmer
Springfield, Il
I will be attending the airshow in Springfield, Il. on April 30/May1. The blue angels just recently canceled their show that was scheduled for a base in South Carolina and are now scheduled to perform in Springfield,Il. on these dates. I will post what freq's I hear in use shortly after those dates.
pocho
I wonder what their practice frequencies are. I guess I'll just program all of the air frequencies given above and see what they're using. They are currently practicing for the airshow here in El Centro for March 12!
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
Search all of 200 and 300 in addition to what was given. More scanners the better. I did this and found they were using frequencies not published. Defiantly do listen when you know there in town. They will talk about all kinds of things. Some of which you wont understand they have like their own language. But in my case hearing them talk about how they could not believe how big the town got and how dry it was was pretty cool. :)
timmer
Springfield, Il
Another thing to do is listen in on the day before the airshow. Here, they usually do a "preview show" or "media day show". They also do a breif practice run that allows them to get the "lay of the land". They note diffrent landmarks that are a certain # of miles from "center point" which is over the show line. I've heard them talk about everthing from the weather to what motel they are going to stay in and what they are going to eat for dinner. It also gives you a chance to get your scanner programmed for the weekend's show, not only with their freq's but others that are going to be used as well, such as parachute jumpers, civilian performers, and air show control freq's.
CORN
Nashville, TN
I second Timmer. If you can get near the show site before the big event you can get great info for your scanner without wasting time scrambling the day of the show. Someone mentioned what their practice frequencies would be. There are no practice frequencies. The frequencies they use the day before (Fri) during their final tuneups will be the ones they use during the show. Yes, it is fun listening to them pick out landmarks and such. I have a chance to see them 3 times this year. Pensacola Beach (definitely) , minus those swirly storms, Chatanooga, Tn. (definitely), and maybe drive to Millington, Tn as well. Plus the T-birds in nearby Smyrna, Tn. It's going to be a great show season.
gus426
Corpus Christi Tx.
Speaking of the Blue Angels, here is a picture of them on the ground at USNAS Kingsville last year, I'm looking forward to their show this year at USNAS Corpus Christi, Tx. April 9 & 10. I'll be there with my Pro43.
Gus
CORN
Nashville, TN
You use a Pro-43 too huh? Thats a very good radio for airshow monitoring. It's been my first to pick up milair. Had mine for 10 years or so now.
RadioJonD
Exalted Nabob
At the hairdresser's, past the liquor store.
The USN Blue Angels used the following three frequencies for their practice shows March 29 & 30, 2005 on NAS Pensacola's Sherman field.
237.800 Ground to air weather briefs. Also heard the boss giving commands at times.
284.250 Diamond formation. Boss commands
265.000 Solos & Delta Formation
These are all new frequencies as listed in the March issue of "Monitoring Times". Check this link for others:
http://www.monitoringtimes.com/html/airshows.html
recon225
Central New Jersey
Thank you for the info. Can't wait until June when they come to NJ. I am a bit bias towards the Angels since they always have a Marine on the demo team.
