glc
I have been monitoring traffic on 172.750 P25. I believe this is the new parkway frequency. Can someone confirm this? Thanks
Nice catch. Can't confirm but added to scanlist for next trip up.I have been monitoring traffic on 172.750 P25. I believe this is the new parkway frequency. Can someone confirm this? Thanks
I started a thread in the NC forums last night about this so those in NC could help out. A reply to that one also mentioned these frequencies: 172.725, 172.450, 173.7625. I am in Stuart this morning and so far I have heard traffic on 172.725 and it was a better signal here than the 172.750. So making an assumption, 172.750 may be Poor Mountain and 172.725 may be either Fishers Peak, Buffalo Mountain, or Grassy Hill. They were not simulcasting.
David Hartman
If the rangers are working from Waynesboro to Roanoke on 172.750, its possible this is the Apple Orchard repeater site. On the old system, there were repeaters at Humpback Rocks, Apple Orchard, Poor Mountain, Grassy Hill, Buffalo Mtn and Fishers Peak. I assumed they might add a site or two along the way since digital seems to require more sites than analog. These were all the Virginia sites I knew of.
The 200 numbers were from Waynesboro to around Roanoke, 300's were from Roanoke to the NC line. 201 and 301 were the district supervisors, 210-219 and 310-319 were sub district 1 ranegrs, 220-229 and 320-329 were sub district 2 rangers, while the maintenance people appeared to take up around the number 50 and up. During the bad weather a few weeks ago and when they were still on 167.175, the maintenance crews were using 260-279 numbers and they were closing the gates and such north of Roanoke.
I didnt know they talked to the game wardens, I was told that they (NPS) used other agency systems but nobody could use the NPS frequencies except parkway units. Some Virginia Game Wardens in thess areas may have the newer STARS radios but they havent switched to the STARS systems here yet that I know of, they are still using conventional freqs unless they can hit a STARS repeater in areas east of the parkway.
But I could be wrong. Wouldnt be the first time. So far no new freqs shown in the NC thread.
Dave
Dave,
This afternoon I did a test to determine if I could receive any BRP P25 transmissions. I used three R7000s and my GRE600 and Uniden 996. One R7000 each was tuned to 167.1750 mhz., 172.7250 mhz. and 172.7500 mhz. respectively ONLY for the purpose of determining the strongest signal strength receptions. Normally the BRP has little comm activity heard here and today was no exception. I also programed my GRE600 and Uniden 996 for 172.7250 mhz. and 172.7500 mhz. I did receive a few P25 transmissions. The best P25 signal strength was from the NW direction on 172.7250 mhz. I also heard very weak P25 signal on 172.7500 mhz. at S1 and nothing on 167.1750 mhz. Although 172.7250 mhz. would have been an excellent analog signal at S5 on the R7000, it was not strong enough to threshold the GRE600 or Uniden 996.
Checking my frequency/user database and reception results lead me to make several conclusions. First, Staunton/Waynesboro is dead on NW from here over a 110 air mile path. In my opinion there is a 172.7250 mhz. BRP repeater located at Humpback Rocks which is located about 6-7 miles SSE of Waynesboro. The extremely weak 172.7500 mhz. repeater signal probably was from a further SSW BRP repeater site possibly at Montebello in Nelson Co. or the Rocky Mtn. site in Rockbridge Co., and definitely was not phased in my direction. Both repeaters simulcasted but I do not recall 167.1750 mhz. simulcasting with them. I cannot hear Apple Orchard Mtn., Buffalo Mtn. or Poor Mtn. signals from here.
I suspect when one BRP P25 repeater is accessed all repeaters in the "backbone" BRP system transmit. This would be done via vhf to uhf/microwave relay links and vice versa to vhf at the various repeater sites in both states using 411.4750 mhz., 411.7000 mhz., 1704 mhz., 1716 mhz., 1726 mhz., and 1776 mhz. As with STARS and SNP I suspect where possible the BRP tries to use their existing analog repeater locations and infrastructure for P25 operations.
When the weather cleared here this afternoon I heard good P25 transmissions from the BRP while they lasted. Unfortunately most comms I heard were under a minute's duration and most of the times less than that..."800 to 214" and then another short transmission "Out of service". "214" must be the HQ dispatcher. Once again I confirmed the best reception was from the NW. Moving the antenna arrays a few degrees north or south resulted in no P25 audio. Surprisingly P25 reception was excellent with only one bar signal strength display on the 996. But the signal was not strong enough to get a NAC id on the GRE600. Humpback Rocks is the suspected location of this BRP repeater.
