Bluegrass Army Depot (Madison County)
Jono40141
Does anyone ever hear anything interesting on this frequency? I haven't really caught much on the channel and I was just asking if anyone knew anything?
natrailblazer
Rockcastle County, KY
I have talked with a member of the BGAD SRT and the freqs listed here on RR are correct. But, there are others that are not listed that are used for security ops. Sorry he was not able to provide me with those freqs for security reasons.
Jono40141
well I guess I could try to figure them out, but I don't really know how I would discover new frequencies on a digital system. If I knew how I would report them to a database admin (steve!). I have a PSR-500. Is there anyway just to scan digital systems?
jerk
jerkville
Go to the Bluegrass page under KY and the County, then up in the corner is a submit button.
Also, when talking with people from the facility, be careful because they might get a letter written to have all information pulled from RR. circumspect is the word of the day. :)
unitcharlie
a Kentucky DB Admin...
on the road to Nonesuch, Ky...
Not sure about the finer points of searching with the PSR 500... basically, do a limit search between 406-420 (that range should cover base and mobile freqs) making sure it is set to decode P-25 and note the control channels... They usually change daily so in a few days you should have the control channels and then go from there... at last check, however, the freqs for the BGAD TRS were still good... the time to search for the other freqs mentioned by natrailblazer would be during exercises, radio checks, etc..... as newsalan points out, discretion is the word....
jerk
jerkville
And from this I wonder what the F-3 SRCH key oesn without using the signal sweeper.
If you are really close, here is a response for the GRE site for Spectrum Sweeper:
How to use the Spectrum Sweeper Feature
Solution
1. PRESS PGM
2. PRESS NEW (THE F1 SOFT KEY)
3. PRESS SRCH (THE F3 SOFT KEY)
4. PRESS SWPR (THE F3 SOFT KEY)
5. USING THE LEFT AND RIGHT SCROLL ARROWS,
ASSIGN THIS PARTICULAR SPECTRUM SWEEPER
OBJECT TO ONE OF THE 20 SCAN LISTS - IF AN
ASTERISK APPEARS TO THE LEFT OF THE SCAN
LIST NUMBER, GO TO THE NEXT STEP - IF NOT,
THEN ADD AN ASTERISK BY PRESS THE SEL KEY
6. SCROLL DOWN ONE CLICK TO TYPE:
7. DECIDE BETWEEN ALL BANDS AND PUBLIC
SAFETY, USING THE LEFT RIGHT SCROLL ARROW
8. SCROLL DOWN ONE CLICK TO SUB-BANDS
9. THERE ARE 9 SUB-BANDS(NUMBERED 0 - 8)
UNDER THE ALL BAND OPTION, & 5 SUB-BANDS
(0 - 4) UNDER THE PUBLIC SAFETY OPTION
10. USING THE LEFT & RIGHT SCROLL ARROWS,
GO TO EACH OF THE SUB-BANDS AND MAKE
SURE THAT THE ONES YOU WANT TO SCAN
HAVE AN ASTERISK NEXT TO THE SUB-BAND #
AND THE ONES YOU DONT, HAVE NO ASTERISK
11. SCROLL DOWN ONE CLICK TO THE TAG LINE
12. IF YOU WANT TO GIVE THAT PARTICULAR
SPECTRUM SWEEPER OBJECT A NAME, PRESS
THE SEL KEY - THEN USING THE STANDARD
METHOD FOR ENTERING ALPHANUMERIC DATA
TYPE OUT THE NAME
13. PRESS DONE (F1 SOFT KEY)
14. TO ACTIVATE THE SPECTRUM SWEEPER, PRESS FUNC THEN SCAN
15. BY PRESSING THE BAND KEY (F1 SOFT KEY), YOU CAN ALTERNATE
BETWEEN ALL BAND AND PUBLIC SAFETY
16. YOU CAN ALSO LOCK OUT SUB-BANDS BY PRESSING THE NUMBER OF
THE SUB-BAND YOU WANT TO LOCKOUT WHILE
::By Glenn from Scanner Unlimited::
Jono40141
Thanks for the reply newsalan. I just saw this. Very Helpful especially now that my county is going digital P25.
Thank you too Glenn!
