Bluetooth and the PRO-95
DickH
I bought a Jabra A210 adapter and a Jabra BT150 headset to use with my PRO-95.
Other threads have discussed needing a 3/32" stereo to 1/8" stereo adapter for it to work on newer Uniden scanners.
Unfortunately, it will not work on the GRE PRO-95. You must use a 3/32" stereo to 1/8 MONO adapter. I couldn't find one in my Radio Shack catalog (2002) so I ended up with 2 adapters; a 3/32" stereo to 1/8" stereo, then a 1/8" stereo to 1/8" mono.
With all that mess plugged in it works very well.
Does anyone know if someone makes a 3/32" stereo to 1/8" mono adapter?
eyes00only
Denver Colorado
You might try a place that installs radios, etc. into cars. Where and how much did you pay for the Adapter? I have a headset for my cellphone that I never use, but I like your idea.
Jerry
lowboy654
DB Admin Member
Northwest, WA
I believe that you can build that cable your self with stuff from radio shack and with a soldering gun you should be set
DickH
Of course! I've been doing it since the '50s. I want a single adapter for a neat connection to my PRO-95. I would cut off the 3/32" stereo plug, connect both left and right wires into a 1/8" mono plug I already have, but I'm afraid the wires on the Jabra may be very small and the cable is not very long. It's a simple process, but I prefer to use an adapter instead.
DickH
Jerry
The 3/32" stereo to 1/8" stereo (RS 274-397) was $3.99 (used to be $1.99). I already have 4 or 5 1/8" stereo to 1/8" mono adapters (RS 274-368), but they should be about the same price.
judyfinkle
40° 20' 41.18" N 79° 49' 59.88" W
3/32 Stereo Jack to 1/8 Mono Plug
This is required for the pro 97 also.
Radio shack has a part # 274-328 $2.99.
It says mono to mono in the headline, but if you
look at the description it says mono to stereo.
I will try one later and hope it works with my A210 and pro-97.
Jay
DickH
Radio shack has a part # 274-328 $2.99. Jay
That's the one that will work on the PRO-95. It is in my 2002 catalog, but I just missed it.
Thanks.
Dick
DaveIN
Founders Curmudgen
West Michigan
So the purpose of the blue-tooth addition is to listen by headset without wires?
Why not just get an I-pod broadcaster (FM transmitter) and listen to it on the car radio?
DickH
That wouldn't work very well at accident and fire scenes. :)
judyfinkle
Well I tried the 274-328 adapter and it does not work.
It is a mono to mono.
The 3/32 end has a M stamped in the metal. meaning mono.
I brought it home anyway just in case, but no good.
If anybody finds one that works, please let me know....
Jay
