Bluetooth Device Compatibility for ADA-01
NZ5E
Bono, AR
I have a Hytera MD782G that I want to add the ADA-01 Bluetooth adapter for use with a Lightspeed Zulu-2 aviation headset in my helicopter. Is the ADA-01 proprietary for use with the SM27W1 Bluetooth microphone or will it work with generic Bluetooth headsets?
I once used a Yaesu FTM-10R mobile radio with the BU-2 Bluetooth accessory in an airplane with a Lightspeed Zulu headset. I would key the radio by briefly pushing the Bluetooth enable button on the headset control module. The FTM-10R had the option in the menu settings to allow momentary push-to-talk or where you briefly pushed the button to activate transmit and then briefly pushed it again to deactivate transmit.
The reason that I desire to use the Lightspeed Zulu-2 headset is that it has a very good noise cancelling microphone. I am currently using a Kenwood TM-V71A and Astatic Road King noise cancelling microphone, but want to change to the Hytera MD782G to play with DMR in the helicopter.
Thanks in advance,
Terry, NZ5E
Pittsboro IN
I tried my phone BT earpiece with the PD982, RX audio was fine but the radio would not use earpiece mic audio. I emailed a couple of BT headset vendors but no response yet.
I guess I need to order the ESW-01. I hope it lets you TX by using the PTT on the radio, I don't think users would want to poke the side of their head to talk.
