In order to use a BT headset with a scanner, the scanner has to be BT compatible. If the LPE is, then any BT headset will work. If it's not, you need the Jabra A-210 Bluetooth adapter and, probably, a 3/32"-to-1/8" adapter, so you can pluf it into the headset jack of the radio. I use mine with a couple of headsets, with my Pro-95, BCD396 or my cordless phones, and I love it.
