Bluetooth Remote Speaker Mic (RSM) that works with both APX and XPR radios?
human8472
Does anyone know of a bluetooth Remote Speaker Mic (RSM) that works with both the APX series of radios as well as the XPR series? I have found Motorola RSMs on eBay and other retailers but there does not appear to be one that works with both. Since they are rather expensive I was hoping to buy a single RSM and use out with both my APX6000 and XPR7550e.
n3obl
ØAES-1056
PA
The operations critical version of speaker mic will connect to both TRBO and APX. The mission critical mics with the blue dot will NOT connect to trbo radios.
K2NEC
5F6
I believe the earpieces are interchangeable however the mics are not. They connect to the radio in different ways.
n3obl
ØAES-1056
PA
Thats not correct as I currently have an operations critical mic connected to my APX and can disconnect it and pair with my TRBO. The blue dot version of mic requires mission critical close contact pairing.
K2NEC
5F6
Oh I'm sorry, I totally misread your comment. Ignore that!
n3obl
ØAES-1056
PA
No problem. Love how text can sometimes be misconstrued.
pete94
To add a little more detail to the above.
The mic I have for my APX7000 is a PN. PMMN4096B. No Blue dot.
I can confirm that it will pair with both XPR and APX handhelds with Bluetooth.
When programming the APX you need to select BLUETOOTHE PAIRING TYPE: Standard or LFMPP or Standard.
Of course YMMV
human8472
Of course YMMV
Thanks for adding this. It helps clarify which RSM works with both radios
