Assuming your aids are in pairing mode (can be discovered); navigate to Bluetooth Settings (in the Function Status menu), set "BT Device" to "On" (blue triangle button), then on "Earphone", push "Set" (red circle), then "Search" (white diamond) - the aids should appear, then you can "Connect"
