Bnc antenna & 106
R
retiredmich
Guest
Need input on this ,I found this add for " Diamond Antenna Dual Band HT 15'' receives up to 900mhz ''
is this better than the 800 MHz antenna ?
reconrider8
Eastern, NC
model number? if its the RH77CA then yes it will "recieve" 900 BUT you want have any kind of "performance" on it you will have to be near a strong signal source to recieve
R
retiredmich
Guest
yes it is the RH77CA. But if you said I have to be near a strong signal source to receive, then this wont work on top of my truck when I'm traveling around ?
R
retiredmich
Guest
I have a magnet mount for bnc, but will this antenna work while I am roaming around in my PU?
hiegtx
Dallas, TX
The RH77CA is a good antenna for Vhf-high, and Uhf. It works "ok" for the 700/800MHz trunked systems with strong signals, but a better antenna for those is the Radio Shack 800MHz antenna.
When I make a trip out of the immediate area, and want to use an external antenna, instead of just the whip on a handheld sitting in a cup holder in the console, I use this mag mount antenna. I get good reception of both the Vhf & Uhf systems, as well as the 700/800MHz trunked systems. Are there better antenna available? Sure, but this does what I want, at a good price. Same antenna at ScannerMaster.
teufler
ST PETERS, MISSOURI
For the price, this is tough to beat. Scanner Antennas
I have used the Sprectrum Force antenna and the bottom of this listing. $19,95 with coax and fitting. Mag mt and small and compact. Not as good as the Austin Sprectre, but 8 or 9 of these for the price of one austin, plus the coax and mt desired.,
