BNC Connectors Wearing Down
TheFlyingPilot
MPSCS Newbie
Frankfort, Michigan
Is there some sort of Uniden Life Hack to fix the BNC connections wearing down? It makes the antenna incredibly loose and wobbly, and I worry that it's affecting my reception. Thanks
dazza0768
Timaru, New Zealand
Shouldn't effect your reception. It's just the nature of the beast. You take your antenna on and off enough then it will wear. That's why SMA is a great idea, you can use adapters.
jonwienke
More Info Coming Soon!
VA
If you're running a base station, use a discone antenna so you don't have to constantly switch antennas. For handhelds, change the SMA-BNC adapter then the BNC side starts having connection issues.
