N_ALSCAN
I finally intend to take the time to re-assemble my monitoring station into something that I can proudly display in the installs section of this forum. Also, this will finally give me a chance to use the stridesburg (sp?) multi-coupler and high-gain outdoor antenna I purchased a few years ago.
However, I want to finally be able to assemble my own cables with BNC connectors. Rather than rely on commercially made cables.
Therefore, I need suggestions on a quality, affordable <$125 set of crimpers to install BNC connectors.
I had purchased a used set, once. They were a surplus AT&T networking set, from the days of computer networks with BNC connectors. I searched the entire local electronics supply and never could get a set of connectors that would match up with the crimpers and strippers (no matter how much I attempted to adjust them). After completely destroying a handful of connectors, I sold off the set.
I would like to find a set that would also allow me to crimp on BNC connectors for CCTV (closed circuit TV/surveillance cameras) using either RG-58 or RG-6.S
Also, if there is a wire stripper that would cut the wire and shield to the correct dimensions, that would save me a LOT of time. Rather than having to measure each cut. I have one of these for satellite dish installation, and it makes my life much easier.
I have even looked into the compression BNC connectors, sometimes referred to as a brand name of snap-n-seal. They usually sell for about $4-6each. However, they are only listed as 75 Ohm. Will the difference of a 75 Ohm connector, versus a 50 Ohm connector, make a difference?
I had hoped to be able to tell you exactly what size coax I intended to use to make the coax-jumper cables to run between the multi-coupler and the Radios. However, I am completely behind the times in the world of coax.
In the past, I've had so much trouble matching the coax to connector to crimper. So, I need suggestions on crimpers and their matching connectors.
Thanks,
Rob
Thanks,
Rob
