bnc male right angle to sma female
Mastiff2013
I googled but I am not seeing quality options. Please advise if there are. Thanks.
I have a SDS200.
jcop225
Radio Zoomer
Boston, MA
Don't see anything from my go to suppliers either.
Is this so you can connect a handheld style antenna directly to the back of your scanner?
jcop225
Radio Zoomer
Boston, MA
Then you may have to stack two adapters to accomplish what you are looking for. If you were connecting to a longer coax cable I would have suggested a short coax jumper with the connectors you need.
hiegtx
Dallas, TX
I have a SDS200.
The SDS200 has a BNC connector, not an SMA. I would simply use a BNC right angle adapter.
For my HP-1 & HP-2, which are SMA, I use the SMA to BNC adapter that came with them, then a BNC right angle.
This is an SMA Male, which would connect to the HP series, with a right angle to BNC female.
Mastiff2013
Thanks. My anttena has a male connector so I need a bnc male right angle toangle to sma female.
hiegtx
Dallas, TX
Ah
You have one or more SMA antennas, from a portable, that you'd like to use on your SDS200.
I did try searching that way (as you probably did), but did not find a "one piece" solution. The closest I found was a BNC Male to SMA Female (straight adapter) then a SMA Male to (right angle) SMA female.
Mastiff2013
Ah
Thanks but isn't the link to a coaxiel not bnc?
wtp
Port Charlotte FL
Amazon.com: Maxmoral BNC Male to SMA Female Plug RF Coaxial Adapter Connector 2PCS: Computers & Accessories
www.amazon.com
so...
radio BNC female
first connector, 90 degree BNC male to female.
second connector, BNC male to SMA female
antenna, SMA male
this would look like the simplest solution.
you can never have too many connectors in your collection.
i use a peanut butter jar just for BNC's.
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
