I've got an AOR LA-400 Indoor Magnetic Loop Antenna which has a female BNC connector at the rear.
I'm using an Icom IC-R8600 which has two cables -- one is for HF between 100kHz and 30MHz and the other cable is used for receiving between 100kHz and 3GHz.
Can I connect the two cables using a BNC splitter (see image below) or should I continue to use a seperate antenna for 100kHz - 3GHz?
