BNSF Live Lafayette sub radio feed
You can listen to the BNSF Lafayette Sub radio feed on scanamerica this feed covers the Lafayette Sub you can hear trains about 10-15 miles away plus some yard ch's
The mainline is Track Warrent control with ABS signal's.which means there can be a lot of talk since Lafayette is a crew base for BNSF and UP changes crews in Lafayette also UP runs Westbound trains on this line BNSF runs both ways.
you will hear these trains.
Amtrak-Sunset LTD
BNSF
L&D-Shortline
UP
Lafayette Parish, Louisiana Live Police, Fire, and EMS Scanners
cgriggs
Mitylene, AL
Hello,
I listened to your feed for around an hour today, sounds good! How many trains is the average for Lafayette per day? I host my own stream as well but use shoutcast, I noticed you seem to be using icecast. What if any delay have you noticed on your stream? I find I have about a 1 minute to 90 second delay on my stream. Here is a link to my stream, Montgomery, AL Live Scanner Stream & Railroad Lineage I am the Montgomery stream. Also you can check it out on your cell phone if you prefer, http://www.moodio.fm/stations_list?title=montgomery&tid%5B%5D=6.
Thanks and I look forward to your reply.
Corey
K4CRG
Hello,
I listened to your feed for around an hour today, sounds good! How many trains is the average for Lafayette per day? I host my own stream as well but use shoutcast, I noticed you seem to be using icecast. What if any delay have you noticed on your stream? I find I have about a 1 minute to 90 second delay on my stream. Here is a link to my stream, Montgomery, AL Live Scanner Stream & Railroad Lineage I am the Montgomery stream. Also you can check it out on your cell phone if you prefer, Stations | Moodio.
Corey
K4CRG
Well Rail Traffic is way down Eastbound trains out of Lafayette are around 2-3 a day heading towards New Orleans right now i hear mabey 1-2 EB and about the same for WB but we also have about 3-4 WB UP Trains plus Amtrak's Sunset LTD.There are also WB BNSF trains out of Lafayette Both BNSF and UP switch crews at Lafayette. Fridays are a mess due to both Amtrak trains that run thru Lafayette.
You can now hear some of the UP dispatchers on this feed there has been a lot of talk on the radio over the last few weeks.
