Boafeng UV-5RE plus help
astolldorf
Waukesha, WI
Hello I am new to this and I was searching through the forums and im not sure I could really find a forum that really was helping me. I was wondering if anyone else has the Boafeng UV-5RE plus that might be able to help me out with some programming (or any one that might now any part of my questions) I thank you in advance to your help and apperciate all the help.
I am A firefighter in Waukesha County (Waukesha and Vernon) and I got the radio because one of the guys I use to work with had one and he used it for scanning and it worked for him. I mainly got as a scanner but may use it in other ways in the future (not completly sure yet how haha) but I mainly want to put in fire channels and the sherrif channel that works in our jurisdiction just to here whats happening in the area.
1st. on the UV-5RE Plus I want to make sure I turned off the transmission abilty. I went to the setting and pretty sure I uncheck transmission function and turned it off but I wasnt to make sure if there is a way to test or turn it off for sure. or do i turn it off for the channels i dont want to transmit on.
2nd. I was able to get the dispatch channel and paging channel on the radio but on this page of the sight it list other fire communication channels and I would like to put those on also (again for listening purposes because if i were to transmit on these channels I would use a dept radio)
Waukesha County Public Safety Trunking System, Countywide, Wisconsin - Scanner Frequencies
this is the link to the page on this site that has the channels i want to input (not all of them a select few)
but I was able to input the dispatch channel because it had a actual frequency listed and it was easy to input that. but on this page it list a decmial format and hex format. is there a way to input these into this radio because the dispatch channel had a frequency like 154.4300.
If you guys plan please help me out that would be great or if there is already a thread on here that talks about this if you can point me that way like I wasnt able to find one unless I was looking in the wrong section
Tweekerbob
1. This may depend on what software you are using, but in general, you turn off the transmit function on a channel by channel basis. So if you've programmed each channel to not transmit, that should be enough.
2. This is referring to a trunked system. The decimal and hex formats refer to talk group IDs within the system and don't refer to any specific frequency. The UV-5 does not follow trunked systems nor does it operate in 800MHz. If you wish to monitor that system, you will need an analog trunk tracking scanner that is capable of handling the rebanded 800MHz frequencies.
