Boat Installation
fireguy810
Im doing an installation on a fireboat. Installing a lowband 46mhz radio, VHF 156mhz radio and a UHF 460mhz radio. I've found marine antennas for the VHF and UHF but I cant find a marine antenna for lowband. So I'm thinking on just using a mobile antenna, but its a fiberglass boat. No groundplane? Anyone have any ideas?
DPapay
Morris County, N.J.
Maxrad used to make a lowband mobile "no ground plane" antenna. We never had great luck with them. Your best performance though would come from making a ground plane for a mobile antenna. Go to your local HVAC supply store and pick up a roll of the stack repair tape. It is metal tape a couple inches wide. Use this on the inside ceiling of the fireboat. Try to make as large a plane as you can. Make sure the antenna base ground is mounted to the tape and it should work o.k. If you take your time, you could make it a neat install, not all hacked up looking.
KC4YIN
Kinston NC
I'm doing something similar. I also need something for VHF & UHF with no ground plane. What and where did you find?
code3cowboy
CA-CZU
You can go with no ground plane NMO or marine antennas, or you can get fiberglass base antennas. I once used an FG4500 on a boat that never bounced around. worked great.
Ref-Jazzy
Indianapolis Indiana
Also referred to as "Foil Tape"
b7spectra
EMS Dispatcher
Cobb County, GA
Van type ambulances (van with the fiberglass top) are also a pain to work with. If you get a view of the top of an ambulance, you will find they usually affix a 12"x12" piece of sheet metal to the top where they mount the antenna (if you have multiple antennas, you have multiple sheets).
