Boosting Freq.
N
N_Jay
Guest
Navycop said:
My radio only gets 380-512 freqs. Can I boost it to 800?
Thanks.
Most probabaly, NO.
But it would help a whole lot of you said what type of radio. :)
BoxAlarm187
Level 6 RR Member (Since 1998)
Old Dominion
He's using a Pro-70, and I will also have to venture a guess of "no".
800MHz radios of all flavors can be found new and used everywhere, but I am not sure if you're in the market to buy a whole new radio or not.
KT4HX
Spotsylvania County, Va
I would have to say no as well. However, it would be beneficial to know what in the 800 MHz range you want to monitor. A trunked system, and if so, Motorola, EDACS, LTR? A conventional system? Analog or digital? Are you looking for a handheld or mobile/base model? How much can you spend? Lots of questions to be answered before you can decide which radio would be best for you.
Navycop
virginia beach, va
Frequncies
I am looking for a handheld, to monitor local pd/fd in va. 50-100 dollars. I need to monitor 856-860 mhz. I wish I knew about MHZ before getting the other one. I thought a scanner was a scanner..
So would a Moto and ericcson tracking PRO-93 with freqs from 25-1300 mhz be good??
KE5BCP
Analog Man
Lewisville, Texas
The Pro93 is a good scanner; the "little brother" to the Pro95 (95 has 1000 channels). It however will NOT work for monitoring Motorola trunked systems after rebanding occurs.
Al42
Long Island, NY, USA
Where specifically in VA? Some of the systems are analog, but for some you'll need a digital-capable scanner.
If analog, a used Pro-95 would work now, but not after rebanding. If digital, expect to spend in the $450-$500 range if you want a chance that it'll still work in 2 years.
Navycop
virginia beach, va
How can I tell what is digital and what is analog? I am monitoring VA beach and Norfolk. I just got in this hobby and now my stuff will be out of date in a few years.
N
N_Jay
Guest
If you listen with a analog scanner and hera white noise it is digital!
BoxAlarm187
Old Dominion
Everything down there is analog except for Chesapeake and the new James City/York/Williamsburg system.
Al42
For any system, just look in the RadioReference database. There's a link to it at the top of this page.
We're all in the same boat - some of our scanners will survive, some won't.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Norfolk, VA Beach, Portsmouth & Suffolk Motorola systems may escape rebanding problems, though each have at least two freqs above 860 Mhz. Hampton EDACS won't be a problem. Newport News and Chesapeake Motorola will require rebanding and the latter is also mixed digital.
