Bootlegger Fire
Northern Nevada/Sierra Front
The Bootlegger Fire started yesterday afternoon by lighting. Its burning in the Ft. Sage Mountains. 2,090 acres have benn burned, Pinyon-juniper, sagebrush and cheat grass are burning. I have pretty good reception in Carson right now, i can pick up the ICP pretty good. Also Minden Dispatch gave out this freq this morning 172.5125, i checked it hand it comes back as Dept. of Homeland Security. Check Sierrafront.net for more info.
Command
169.7750/169.0250 BLM Carson Dist
Tacticals (Im guessing on this one)
154.280 White Fire-1
171.6750 BLM SOA
Air Frequencies
165.650 A/G Primary
120.975 A/A Primary
168.650 Flight Following
