FAA still has both primary (skin) and secondary (transponder) radar.
The skin track may be digital video, but it is still generated from a real radar return. So it is not wrong to say the FAA is pretty much all digital, but digital does not mean no skin track capability.
Think about it this way, even if all of your long range stuff relies on a cooperative target (a transponder of some kind), you still need the ability to see a non cooperative target, such as rain, windshear, an aircraft that forgot to turn on the transponder, or an aircraft that has a failed transponder and is NORDO. So even though transponders are the primary mode these days (despite still being called secondary radars) it will be a long time before the FAA gives up the ability to do skin track.
With that said, FAA radars are not designed to work with very small RCS targets. When you design a radar you do so with a target set in mind, size, shape, speed, etc. You don't spend the effort, and associated cost, to build a system that is optimized to track a -10 or -20 dBsm target when the smallest aircraft you anticipate tracking is probably in excess of 0 dBsm, and most commercial aircraft will be well in excess of +10 dBsm.
It would not surprise me that even if they were specifically looking for drones with FAA skin radars they might have trouble seeing them. It is actually a tough target set to deal with. The skin return might be very low, with specific narrow angles of high return, the motion Doppler might be low, and the high Doppler portions of the aircraft, say the props with all their wide Doppler smearing, are generally made of low reflectivity materials.
T!
