Yep sure does, but keep an eye out, there will soon (soon meaning in the next few weeks) be a newer version out. I've split the new ones up, so the 330 has it's own app now with it's own name and color etc. So, less confusion is on the horizon for those that run both at the same time (like me).
Hi Brian... quick question regarding Scannerbase. I downloaded the full installation off your site, but when I come to install it, it says some files needed to be upgraded before it can go any further, I click yes, then I click yes to restart Windoze.
Come back to the installer, and it says the same thing. I've re-installed Windows once to try and fix the problem.
Version is XP Pro and I think SP1.
Edit: I got the program running by just extracting the .CAB to a directory... not very clean, but it works.
Sounds similar to what Win 2k users report seeing. You may have to manually install it, but first just try running the program as is. You may have all the DLL's necessary to run the program installed already. Failing that, just email me (software@scannerbase.com) and I'll see what I can do to help you out.
