We already have a
two site DMR Capacity Max system for the city. Today I am seeing a TIII Standard system show up using the same talkgroups as Capacity Max.
MOT is CAPMAX. Im guessing the signal isn't great so DSDPlus isn't changing everything. But if it is detected as MOT, it is a CAPMAX site and the Site:S2-1.3 is wrong and you should be able to get a correct reading with a better signal or by having it repopulate that data on the screen.
Go to CTRL --> Discard Current System Info
if the signal is good enough with no interference it should show MOT, swith to TIIINonstd and the Site information should change. That is unless you've specifically overridden things by adding stuff to DSDplus.networks / dsdplus.sites / dsdplus.frequencies. If you did that, I would comment anything out in DSDSPlu.* files for this particular site, then park on the control channel again and see if it comes up as TIIINonStd (MOT) Site:#-#
Mike
