badbanterer
- Joined
- Mar 19, 2022
- Messages
- 5
Hello,
I tried to configure a home CB set up but I clearly do not know enough to have ordered everything I need and I don't know what I don't know.
I got a CB Bearcat 9800SSB for backup communications. This is meant to be primarily for home (base) but I did not get it to set up some kind of elaborate set up. I purchased a power supply, a mount and 3 different antennas to try:
Little Will
WILSON 305-495 3500-Watt Trucker Antenna (Black)
FireStik FL3-B Three Foot FireFly Antenna With Tuneable Tip (Black)
I have a 60 V PS set to 13.8 V and 4.5 amps. Connected them using a Wilson Antenna 305-830 18' Belden Coax Cable with PL-259/FME Connectors to a Workman Double Groove CB Radio Antenna Mount W/ SO239 Stud BRV1. I used a thin solid wire to ground the Firestick and the Wilson Truckers antenna to the ground of the power supply, the Little Will has its own cable.
Ok, I think those are the basics. I get SWRs greater than 3 on 1, 20, 40. Depending on the antenna, 1 might be lower than the other two channels but still over 3.
From what I see, it could be grounding and I checked everything I could without a multimeter but I think that I am missing something very basic that any one of you could spot right away from my description. Either wrong type of antenna or perhaps I need some kind of ground plane?
Any pertinent advice appreciated.
Thanks,
Jorge
Little Will
Thanks,
Jorge
